BigBlockMopar28
Looking at the 10 x 2 1/2 drum kit by dr diff. I have an a body 8 3/4 (unsure of year, 742 case), and factory length bbp axles. Should everything bolt up without issue? TIA FABO!
Dr Diff... nuff said. You'll never EVER go wrong with him. He will set you up right. Just give him a call.Looking at the 10 x 2 1/2 drum kit by dr diff. I have an a body 8 3/4 (unsure of year, 742 case), and factory length bbp axles. Should everything bolt up without issue? TIA FABO!
Mopar Axle Package 5 X 4 1/2" (5 X 4.5) Bolt Pattern 30/35 Splineare the big bolt pattern factory axles a body length? and are they a body brake offset or b body brake offset? check markwilliams and moser and strange websites
