Demon 408
I'm trying to gain about 1/2" to 1" clearance for my Mopar Performance original-style (unsilenced) 13" Air Cleaner. Has anyone found a drop base that works with these air cleaner assemblies? Thanx.
Thanks for the inputs. The Mopar unsilenced Air Cleaners are 12.75" in diameter. The Ford Motor Sports air cleaner (link in Dogbreath's post) is the closest that I've found to the correct size. But you've got to buy the entire air cleaner...maybe it's time to break out the cutoff wheel and welder and make my own.
Do you have a spacer between your carb and intake ?
Memike,
Thanks for taking the time to dig up the air cleaner and pics. I've got a 14' inch drop base in the shed and was considering making the same "adjustment" as you show in your pic. As you know the unsilenced Mopar air cleaner base is smaller than the top because the air inlet is provided by the gap at the bottom between the top and the base plate. Perhaps, not the most efficient design, but it's Mopar and it's what I'm trying to stay true to in this build.
I wasnt able to fit my OEM 340 air-cleaner(which is a drop base) with a 1/2" spacer under the hood.
My intake is the Ede RPM,which sits higher than a stock 340 intake.
I ended up using a Edelbrock heat insulator gasket which measures around 5/16". Just that little amount made the difference.
What paint did you use on your exhaust? It looks great!
You are very welcome Demon 408 :happy10: Good luck and keep us updated :happy10:
