moparspares
Pic 1 Firstly Remove the round wiring plug which is located above the speedo cable and a little to the right.
Pic 2 Remove the Speedo cable by squeezing the clip and pull towards front of vehicle. Sorry my clip is broken but you can see what I mean.
Pic 3 Remove the one screw from fuse block and push fuse block out of the way.
Pic 4 Reach right up behind dash and light switch and feel arouind for a spring loaded button. Push this small button while pulling the light switch outwards.
Pic 5 Pull wiper swith button to remove
Pic 6 Remove light switch and wiper Bezels by unscrewing. You can buy a tool for this but I made this remover in about 5 mins with a bit scrap steel. then push back away from dash.
Pic 8 Remove two nuts on either side of steering column and gently pull steering column down 4 - 5 inches. Then remove the six screws on front face of dash 3 upper and 3 lower
Pic 9 Gently pull dash forward and with a little jiggling around the steering column. Walla you have it out. There is still 2 wires behind ampmeter guage - mark and remove.
There you have it you can now go and restore it.
