Early B 8 1/4 fits fine
BWDart
New Braunfels TX
Got the 8 1/4 installed today fits fine, they are 44 oc sprg perch to sprg perch, no spring binding. Needs a little work in the trunk!!! Will also install the new EBC slotted rotors this weekend and measure for the drive line. Got the frame connectors in last sat and built a new cross member for the trans. Hope to get it running this weekend.
What year did that rear come from?? I was toying with doing a disk brake set up on the back of my car.
Don't let those mufflers cook your new rear end. (And it will like they are now)
Blows the axle seals and boils your gear oil from the heat
Wish someone had mentioned that to me about 6months ago.....
This rear came out of a 70 Charger. I have the disc set up for the rear but will be using the drums for now. The exhaust is not done yet I wanted to get the rear end in first then route the pipes.
