What is everyone running for electric fuel pumps? I am ready to purchase one and would like your input. I will be running a filter between the pump-tank and tank-engine. The car will be a street cruiser and limited time at the track. :brave:
I am the only one that is running an electric fuel pump? Really??? Don't be so shy... I don't bite... much. lol :brave:
same here , 5-7 psi . can barely hear it workingI bought a Carter electric nice and quiet, better design than a holley.
the aeromotive is a good pump, but requires an additional 350 dollar pump controller, or you'll burn it up...
I have a Holley HP150. Its a bit loud but the car drowns it out when it's running They have an internal bypass so you don't need to run a return line if you don't want to.
I'm running the same pump with a return line.I find it quiet compared to most external pumps.
Do you know the hp of your engine start with that. If you don't plan on making more than buy a pump that will service the hp requirements! You need to buy a pump based on the gal per hour needed .
I guess 500+ HP, I have a purple shaft cam out of a friend's car but have no stats on it. Can you buy to big a pump and then use a regulator to control the fuel to the carb?
