pastortom1
2 years back, I installed a Holley electric pump on my 67 Cuda....it's a 273 2bbl, so I installed the small one...........worked great, but I HATED the noise....I isolated it 2 ways, and still the noise......
Well, the car is driven very little.......My daughter just fired it up (with a LOT of difficulty) and tried to get it to a car show....it died 3 times, then wouldn't start at all........They tell me that the pump was making a ticking noise after they fired it up, but then it stopped......then the car died downtown.....
This pump had less than 200 miles on it.........Mechanical pumps just don't run worth a baloney on the car (probably the cam lobe....could use a new cam), so I want to stick to an electric..........
BUT, I want a dependable pump.........200 miles just doesn't cut it with my money.
What other pumps could you guys recommend? I want one that will last, and be suitable for a stock small block. :read2:
