What car are you working on? Check your bulkhead connectors and/or fuseable link near the firewall. Also check the back of the ammeter under the dash for tight connections.
the headlights and the ignition switch/ accessory hot feed are all fed off the "no1 splice" inside the under-dash harness. Since the headlights work and nothing/ little else, that is where I'd look. Neither the headlight feed nor the ignition switch feed are fused. They both come in off the bulkhead connector to that splice, both fed directly
