64ragtop
I thought I had the solution to the wiring woes that caused and/or were caused by the horribly burned bulkhead connector I showed in my previous "Electrical Woes" thread. I ordered brand new engine/forward light and dash harnesses and was assured that they would be "completely plug and play". Suffice it to say that they are NOT! Sure the wires are really pretty, and seeing shiny metal in the fuse box and all the connectors was kind of a thrill. Then I crawled up under the dash and laid the new harness out in nearly the position it will end up in, and discovered the three missing circuits from both harnesses. It seems that the harnesses are for a low line '64 Dart. No provision is made for the variable speed windshield wiper & washer or the backup lights. The fusebox has clips for only five fuses & seven are needed.
Sure, I could cannibalize the old harnesses but as soon as I start cutting the new harnesses there goes the warranty. I am disappointed and frustrated, but I have hopes that the harness maker will correct the omissions. Patience is a virtue that I do not possess, and the process of getting these harnesses corrected and the time involved are going to be unpleasant, mostly because it was unexpected. Please pardon the rant and take salesperson's promises as being worth the paper they're printed on.
ATB
BC
ATB
BC
