The number after the CID is a casting mold revision number. In this case we will use the number you provided 353363830 440 6
The actual number on the block is likely 2536430 this is a 66-72 440 engine.
the 440 is the CID identifier.
the 6 is the block revision number. This is the number of times the block cast has had a change to its mold from the original mold casting. After a certain number of revisions a new casting is used. On small blocks I have seen them go to about 9. On big blocks I have seen them as high as 14.
Some say the lower the revision number the better. I am not sure there is any real truth to that?
So the 6 does NOT equal a 6-pack engine. On the top front ID plate on the RB engine. A 6-pack engine will have the HP2 stamping, but so will other High Performance engines. I have been told the 6-pack engine were made on the second shift hence the HP with a 2. My research seems to agree with this, but I can say it is an indisputable fact.
