On a 340, generally the low compression pistons have 4 valve reliefs...and high compression have 2 valve reliefs.
you can measure from the top of the wrist pin to the to of the piston and add .492 to get the compression height of the piston...
340 high compression is 1.84,,,,low compression is around 1.72
360 should be around 1.67 for high compression
