No, epoxy primer is a sealer. It will seal everything under it. With that said, the paint under it should be in good condition. I usually sand thru the paint but not thru the original primer.
You sould make sure that all the rust has been removed and epoxy before body work is completed and then epoxy over the spots around your body work that you sanded through something that help me is I spray high build over the epoxy the same day but make sure your epoxy is dry it helps keep your sand paper from guming up! Hope it helps good luck!
