octanejunkie
Mopar Padawan
The previous owner of my 71 Scamp did a few upgrades planning on running the car, one of his mods was an electric fuel pump, an autozone special by appearance.
When I changed the oil on the car I got about 7+ quarts of black stuff with the consistency of milk out of the pan and it smelled like gas.
I did a compression test. Got around 120 psi on most cyls. Checked floats and cleaned carb out real good (Carter 4-bbl 9926) and checked fuel pressure - 8-9 psi from that electric pump.
I thought 4-7 psi was all that was required...
On one or two instances when test driving the car it has flooded, an actual puddle of gas on the floor of the intake manifold. All other signs like plugs, etc indicate an overly rich condition...
Is it possible that the fuel pump is sending too much pressure to the carb and overrunning the float valves or is the carb bad?
