exhaust manifold i.d.
340wedge1971
Marblehead Ohio
can anyone shed some light on this manifold?A guy said it was a 340,but it has a 1974 cast date. "L" code 360?
I cant make out the first pic due to it being so small. There is a 2nd generations so called "HP" mainifolds that were for 340/360 manifolds as I understand it. If compared to say the 318 driver side you will notice the outlet is quite a bit larger on the 340/360 version. I believe that is what you have.
-RPM
Per: http://www.mymopar.com/extcastnumb.htm
340 1969-70 Dart / Left 3614368
Perhaps a stock replacement?
That list has so much crappy info in it, it's not funny.
That's not even the correct number for that app listed.
3614368 LH 1972-74 A-body 340, 360
Yes with that casting date it's a 74 360 manifold, but, still same base as the earlier 340 piece..
Good to know CB, thank you.
Is there a better, more accurate exhaust casting reference list out there?
