stumblinhorse
Was going to do headers and noticed I had a broken stud on the back corner stud. So I am going to pull the heads and get it out and probably a valve job when they are off.
I have done a bunch of searching and all I can find it this part from summit
Dorman Double-Ended Studs 675-001
Grade 8, Zinc Plated, 5/16 in.-18, 5/16 in.-24 Threads, 1.500 in. Length. 0.250 in. shoulder length. Stud measures 3/4 in. long on the course threads and 1/2 in. long on the fine threaded end.
Mancini has a whole set for a small block. But my Hedman's come with the appropriate bolts and just wanted 4 new end studs.
Will those work? Or where do I get others that will. Thanks!
