pishta
I know I'm right....
if anyone of you guys with lo output motors are running a Facet style electric pump (the "jiggler" style) that is cylindrical shaped (as opposed to a transformer looking thing) let me tell you what I found when I ran mine. Im idling my motor to get it hot for smog and the motor dies after 10 minutes. I look at fuel bowl and its empty. I turn off and on again but the fuel pump is dead. I touch it and it almost burns my hand, so its got 12V but its not doing anything (including passing fuel to cool it) so off it comes. I grind the crimp ring off and it seperates, dumping a bunch of liqued in the process. Its not fuel, its water! WTF is water doing in my electric fuel pump? the cap that I took off (the output side) contains a circuit board and the wires along with the tube for the piston. There is a rubber seal that goes over the tube and into the cap so no fuel can get into the electronics cavity, but sho'nuf it was full of water by the waterline I could see on the wall. This is a mystery: could water seperate and enter the cavity past the seal when gas could not? could I drill a small weep hole in this area to facilitate future draining? Its a naked SMT PC board so Im sure gas should not be in contact with it and the water seemed to be shorting the PCB as it started to work again after I drained and dried off the PCB. Its back together and I spot welded the cap back on, ran it for 10 minutes, no leaks and seems to be working again.
