59bisquik
Ok guys, I don't have a A body car but use a 340 distributor setup in my 57 325 Hemi engine. I got a kit a few years ago that was a replacement for the older points distributor. It has the module, ballast resistor etc.
The truck has been sitting for a while and when I went to fire it up, I had no spark. I troubleshot it down to the ECU. I have replaced it once before for the same problem.
I seem to find a pile of discussions talking about how horrible aftermarket ECU's are. Since I have replaced it before and and don't want to keep replacing ignition modules, I decided to replace the ECU with the HEI module. I got the new module in and it fired right up. It ran for about 5 minutes and then quit and now has no spark. Napa was supposed to have a good module and I will try to return it tomorrow. Maybe it was bad off the shelf. However, what am I doing wrong that I keep going through modules?
