coffeedart67
67 Dart, 273 2barrel, auto, 22 inch rad. thinking of doing some cooling mods, been looking around for clutch fans and oriellys or advance lists a thermal fan clutch and a non-thermal. which do I want? Is there a source for the 17" fans for the fan clutch, I have a fan left over from the race car, nice 5 or 6 blade(not a flex fan)will check diameter. will I notice any difference in power with the clutch fan versus the solid fan?
I think I am going to make my own shroud and am just wondering how much clearance I should give around the fan.
the car doesn't overheat (usually runs about 1/2 to 3/4 on the stock temp gauge)but does go to the notch just below "H" in slow cruising/parade type situations.
Thanks
Aaron
it is a 17", 6 blade non clutch fan
Thanks
Aaron
