Where are you guys getting your 12v with key on feed from?
Sorry I missed this one. Probably not much help though, mines pulled from the continuous duty relay that’s part of my battery relocation.
Anyone know what Dakota digital sender they are using? I have a big block
The controller? It’s
Dakota Digital Programmable Dual Fan Controllers PAC-2750
If you mean what temperature sending unit I tied to the controller I just used the one for my auto meter temp gauge. There are several sending units that are pre-programmed into the Dakota Digital controller, so you just pick the one you’ve got when you’re setting up the controller. There’s even a way to custom program the controller for whatever sender you have if you really want to get crazy. But most of the big brand brand senders are pre-programmed.
