fan shroud
justcuz
Rating - 0%
0   0   0
looking for a 22" fan shroud to fit my 71 Demon 340
Chrysler part# 2998325
pls PM with details
Are you looking for OEM or NOS or just a shroud ? Ever consider building your own ? There's a couple of threads on doing that.
I found a 22" shroud locally part # 2998 328
seller said it came out a 340 Duster 4 speed???
will this fit in my car without any problems?
I think the shroud # you posted fits a B or E body. Your original post w/ #2998325 is correct for your application.
still looking for a 22" fan shroud to fit my 71 Demon 340 4 speed.
would prefer NOS Chrysler Part# 2998325
appreciate all the leads but still no luck and making one is not an option
for me
Pls PM if you have one.
thanks
i read somewere the repop ones warp???????
I've read quite a few threads here on FABO about the re-pop shrouds warping.
An NOS #2998325 would be quite the find justcuz =P~. Even a nice used one can be made to look super 8). Good luck and here's a bump for your search.
thanks for the bump 6pk2goDemon
a used one in good shape would be fine too
i got a nice clean used on with the numbers2998325 out of a 71 340 duster that i am starting to part out 225.00 plus the ride
I think I have one at home and will check in the morning.
I found one and purchased from a fellow FABO member
thanks to all for your help
much appreciated!
