[SOLD] Federal Power Steering Pump & Brackets 70-72 Small Block
goldduster318
Overzealous Car Modifier
Lake Orion, MI
For sale:
Federal Power steering pump+ Brackets for 70-72 A-body with a small block engine, with a hose for a 70 Duster. This was used on my personal car until I swapped to a Saginaw pump when I installed Hydroboost.
Pump was reman in 2013, fresh fluid through the entire system at that time
Hose is also from 2013, worked well
Pulley has a little wobble but was never an issue (belt stayed on at 6000+ RPM)
I can't think of a time where i've seen a complete setup like this for sale. This is the only power steering system that fits without modifications on the 67-72 K-frame with an aluminum 70+ water pump and pulley set.
$200+ the ride
