Fender pentastar emblem.
Peter L
Active Member
Ontario Canada
Hi guys. Looking for some measurements as to where the gold pentastar emblem goes on my '69 Barracuda. I used the search but only found them for the Dart. Are they the same? I just want to be sure I get it right. Thanks.
Heres 67 cuda, sorry tough to get super accurate with tape measure and rocker mouldings in the way...
All the Pentastars are the same, if that was the question. I can take measurements without a rocker molding, if that helps.
Long ago I checked several different 1970 Challenger fenders & none of them matched exactly.
Fenders were stamped at different times, by different people on different machinery.
Here's my measurement without rocker molding. My two Barracudas measured slightly different from the wheel well molding, but that's probably just based on how well the molding fit — at least of them is a repro set. The vertical measurement is along the curve using a tape.
