340wedge1971
Any thoughts on running with fiberglass bumpers for the street? Looks?weight? price? examples?
do you guys use the factory bumper brackts...otr make new ones out of aluminum?
If you look closely, I'm only using one of the two OE brackets on each side. I figured if I'm going to get into an "issue" with a glass bumper, having an extra bracket isn't going to help much. Besides it's just more weight :toothy10:
what ever the hell happened to that dude who was making aluminum bumper brackets for our cars who were runnin fiberglass bumpers?
If I remember correctly, the price was a lot more than most are willing to pay- something like a couple hundred bucks to save around 15 lbs. You can use a hole saw and cut several holes in the stock brackets to save a few pounds to get them almost as light as aluminum would be. I also removed the outer brackets.
I guess I need to get back in the gym. It felt like just the 2 outers were about 10 pounds, but I never put them on a scale to see. Even more reason not to spend the money on the aluminum ones. I've thought of getting the fiberglass ones when I get a fiberglass bumper, but I'll probably just lighten the stock ones like you did (I think yours are the ones I was thinking I had seen pics of before).
