JGC403
Is a cheap floating-pressure type flow bench worth building?
I stumbled across this site:
How to Build a Flow Bench for Port and Flow Testing Cylinder Heads - Part 3
I like the idea of the low budget flow bench described in the beginning of the webpage. I don't really need to know what the actually cfm of the heads are, just as long as I can see an improvement while I'm porting and to be able to compare the ports to the other ports in the head and make sure they are flowing evenly. I think it should be good enough for that, what says everyone else? Is this type of flow bench worth making? better than nothing? not worth it?
