[FOR SALE] Front and rear suspension ++
DentalDart
Ozark Missouri
Replaced the entire front end on my 69 Dart so these are the parts I have that need to go to a good home. The parts are from a sbp 5x4 car, so small ball joint uca's (correct me if I'm wrong at any time). I dont know when any of the bushings were replaced some look great others may need replaced.
Upper control arms - $75?
Lower control arms - $75?
Pitman arms- $20?
Torsion bars (spare set from 68 gts)- 100
Rear 10in drums- complete- pads and all hardware replaced in August, everything has about 500 miles on it. -$100? 80?
Front 10in drums- complete- will come will all new pads and hardware. - $100? $75?
4 kyb gas shocks (front and rear) - still pretty stiff but compressible - $40 + shipping?
Calipers from 88 diplomat- $15?
Dual reservoir MC from 88 diplomat -$15?
Steering linkage- - $40?
Parts idk name of-
2 sets of wheels-
Ralye with tires - 14x7 sbp with 245/60 rears and 235/60 front Goodyear radials. 2010 date on rears and 2011 on fronts - you pick up unless you really want to pay the large shipping prices for these- $450?
Mopar steelies- 15x5.5 bbp - $50?
Dog dish caps - $75?
Complete 7 1/4 rear end with backing plates and if you want the drums with it that can be done. Again pick up preferred as shipping would be a PIA. - $150? $90?
I'm not familiar with pricing this stuff I see prices but dont know how to price all this. I need room in the garage and dont want to horde parts that I won't use. I also have my manifolds but havent had my offers on those so they will most likely go back in a box.
Located in Las Vegas
Make me a fair offer and you pay shipping
Mopar Steel Wheels sold (pending payment)
Stock drum brake A body spindles sold (pending payment)
340 72hp manifold is pending sale/payment/shipping
Lmk if you want anything, if my prices are bad and you want a better deal. Let's get this guys garage free from extra parts :thankyou:
LCA"S still available? if so do they have sway bar tabs?
Thanks
Thanks
They are available. I'll check on the tabs in a bit as I'm taking care of my kiddos right now. I didnt even pay attention to the lower control arms and if they had tabs. My apologies.
Yes they do have sway bar tabs, just not welded to the CA's, I believe I have a stock aftermarket sway bar and the tabs are bolted to where the shock bolt goes. I have a set with some welded to them though if you absolutely had to have the stock ones with stock tabs. :thumbsup:
Would you be willing to part with the front spindle nuts?
Rear 10"x 1.75" Drums with all associated hardware (including parking brake hardware, wheel cylinder rods)?
Front spindle nuts? Just the nuts? Or do you want the bolts too? Lol.
Rear drums yes, the only thing that confuses me is the parking brake stuff, like the cable too? If so I kept and reused the cable. If you're talking about the entire drum with all the parts that are used inside of it to make it work, yes I dont need it. It is 5x4 sbp and I went to bbp
Yes, just the nuts that are used to secure the bearings onto the spindle. I stripped my one nut...
I do not need the cable, I actually got new ones of those. I just need the drums and all the stuff that stays inside them
Dental, please pm me your number as your pm box must be full.
Thanks
All 4 shocks sold- pending payment
Rear drums and cylinder rods sold pending payment.
Thanks everyone!
Caliper brackets and calipers are for 11. I have no clue if they work well I havent used them, Is there a way to test them?
Maybe someone else can chime in about a test. I was basically wondering if you knew them to work when you pulled them off the car. I’ll pass in this case since I can get cores locally. Thanks!
Pitman arms- $20?
Some of your pricing seems on target but nobody will pay $75 for small ball joint Upper control arms. Every 63-72 A body came with them so they are the most common. Stock torsion bars are essentially worthless except for the 5% of guys doing OEM restorations.
I've sold at swap meets for years and have found that most of the low end parts ( Front drums, 7 1/4" axles, stock torsion bars, etc) only appeal to the restoration guys. Most enthusiasts want to upgrade from those parts they already have on their cars.
10" rear drums are a good score. Somebody will want those shocks. Not me but someone will.
Good luck.
Good luck.
Thanks! I didnt know what to price stuff at, didnt have prices originally just asked people to make a fair offer because they'd know the prices better than me. I only put prices to not get in trouble and found prices on FABO of recent parts, but again they are only there so I dont get in trouble. I'm open to any offers.
Rear drums are gone, shocks are gone, sway bar is gone, front spindles are gone, LCAs and others. Really I tried giving away an exhaust and rear end and didnt have any local takers lol.
