Hi Guy's,
I need a little advice on a new fuel pump. I am running a 110 GPH Holley mechanical pump now & since we have installed a stroker crank & new cam the pump is not keeping up in the top end.
I have seen advertised a Edlebrock 170 GPH mechanical pump or would I be better off spending the $$$ on a electric pump & if so what pump would you recommend ???.
Cheers Oz
Cheers Oz
