This Bad Demon
This is a few questions on wiring a fuse box. Ok I'm working with a 1972 Dodge Demon...I have a fuse box from a 1992 Plymouth Sundance. As you know there is more fuse's then the box in the car now...First question. The sundance box has a fuse for the wind shield wipers with one side connected to a strip which connects to the accessory wire. The next side has two blue wires from it. How would I wire it to the existing wires for the wiper motor?
Question 2. The turn signal is on that same row as the wiper motor with the same setup on one side but only one wire coming from the next side. Would I cut the wire for the flasher from the key switch and join it to the one on the fuse box?
Question 3....I have a full MSD setup on the car. I also have the Fast EZ Efi system also....I wanted to take the fast system off the switch I have it on and install it on the key switch. Do you think if I hook up the 12v switch wire to the blue and brown wire that triggers the msd would you think it would be too much radio interference for the Fast system to work properly? [/FONT
