68gtxman
I used to reMember
i have a 2008 GMC Yukon Denali XL AWD (only put a couple 1,000 miles on it so far). I noticed that the volt meter in the dash would sometimes read right at 14.0 volts and other times it drops to 12.3 volts. After a cold start, it immediately goes up to around 14.5 volts, but as the engine warms up, the voltage slowly drops to the mid-12s. I plugged in a digital voltage meter into the cigarette socket and the dash gauge is not showing accurately, but close enough. While driving today, I noticed the same voltage drop to 12.5 - 12.9v regardless of engine RPM, but when I turned on the headlights, it rose and stayed at 13.8 - 14.1v.
Does this mean the alternator is going out (it,s been doing this apparently since I got it in March of this year). Or does it mean that I have a bad ground or ground cable? Any experienced mechanics see this before???
