Top down for the first time in over 30 years. Cover looks as good as day one (the underside is a bit worse for wear)
Hydraulics worked flawlessly, OE clear fluid, still full.
Not so sure what the top will look like when it is back up, a lot of cracking and snapping on the way down. (needs to be replaced anyway)
Luckily it was a hot sunny day so things were soft(ish) and pliable.
