74Dusted
Stock Piler of 340's
Yep, Got really bored and wanted something to do, So what did I do?
Pulled my truck (1984 Dodge D50) in the garage, yanked out the 2.6L 4 cylinder & 5-Speed.
Originally a Mitsubishi 2.6L Gas engine, that had been swapped to a 2.5L Intercooled Turbo Diesel, and then another 2.6L took it's place for a while. This truck has played "Musical Engines" for a long time.
Going in it's place is a '69 273 with 587 heads & a 340 Intake, with a 904 Torqueflite (4 Pinion Planetaries and internals from a MA904, and a Semi-Auto Shift Kit) with a KM100/NP203 Doubler Transfer Case setup. The 273 ain't pretty, but it runs
It's a tight fit at the Hydroboost (I'll actually have to unbolt the booster/master cylinder to change 3 of the plugs on the driver's side) and requires a 1964-66 A-Body Manifold on that side to clear the steering column. The Passenger side can run a regular Truck Manifold, but requires a 90* Oil Filter Adapter to clear the frame & fenderwell
The core support requires modifications too, because the engine/transmission were moved 2" forward when it was a Turbo Diesel truck. It's easier to relocate the radiator/condensor/cooler than it is to make 2 new driveshafts :mrgreen:
And for good measure, what it looked like before i started ripping it apart
