diymirage
HP@idle > hondaHP@redline
As you guys might know, I got a little 19ft Bayliner
I had it out for the first time of the season the other day and while putting it through the paces i noticed the bilge pump didnt work
not surprising since there was no water in the bilge BUT i also didnt hear it hum...which i normally do
so i checked it out today, started at the switch and there was power there
checked the fuses, down to the wiring and all was well, but the pump just would not kick on
so i took it apart, put straight 12 volt to it and it spun
so maybe the whole thing was clogged up ?
took everything apart, cleaned it and and dry tested it and all was well
put it back in, used the hose to put some water in the bilge, turned it on and it spun for a few seconds, then sounded labored and finally stopped again...almost like it was running out of juice
out of juice...or into a wall
so i popped the discharge hose off and and let it run for a few minutes and all ran fine, pumping a good stream of water out of the pump and into the bilge
fired up the compressor and blew the discharge hose out and tried it again
(now i did not see any obstructions pop out of the hose, or worse, a swarm of wasps) but it looks to have fixed the issue
needless to say, i was tickled pink to get it fixed for free
