not in a a body but my 05 ram 1500 4.7 quad cab has a leaking head gasket on #1 cylinder cant tear down and do a proper repair now what is a good gasket sealer that will fix or slow down the leak thanks sandy
Bars leaks head gasket sealer. Not the cheap stuff. This stuff is around $80 a bottle if i remember right. Works good aslong as its a SMALL leak. If its large leak youll never seal it, youll just plug your cooling system. But if its small the more you run it the more this stuff seals
