360 la heads, I had the 4 end holes in the heads heli-coiled as they were all broken. Now the pass side rear is leaking water should I silicon it along with the gasket? Thanks
Bruce
studs with the coned washers that is why they are used on the ends of the manifolds from the factory. They will fit and should be used on all exhaust applications. 4 per engine
Thread chase, clean with starting fluid, blow out, let dry. Use "right Stuff " from Napa, or Coppercoat, or Teflon past. Let cure for a day. Problem area, on an engine that shade trees have stuffed so many chemicals into, lol.
