Heater line block off.
Crazy4408pac
N. Michigan
Traverse City Michigan
Not running a heater, so don't need the lines from the engine to the firewall. Any suggestions as to how to block them off? I'm thinking of using plugs, at the engine and teflon tape.
Thanks
At the fire wall just take a piece of hose from one to the other. Off the water pump use a piece of pipe inside the hose, couple of clamps and go.
Used these rubber plugs on heater core and the previous owner of the engine had used a piece of wood and hammered it into the nipple on the water pump but I put a runner cap on it to be safe.
These look way better and perform the same purpose as looping a hose
Keeps the engine bay all nice and tidy
Put a plug in place of the fitting on the intake and thread the hole on the water pump for a pipe plug.
