E55D21
HOB230933
Ok I admit I'm not the brightest bulb when it comes to electrical issues..
There's a "can" under the dash under the radio, near the ash tray.. It's a round can about the size of my thumb.. I have no clue what this is, or what it does.. It's got a 3 prong plug on it.
The outside of the can fell off exposing the inards. It shorted on the dash blowing a fuse.. It may or may not be related but I had breaklights until the incident with the can. I put the outside of the can back on and bent the tabs so it wouldn't come off again
Now for whatever reason I haved no break lights.. I have turn signals, running and flasher all work just not breaklights.
I traced power all the way through the breaklight switch on the break pedal.. Lossing trace once the wire off the backside of the switch goes back into the harness...
Since everything worked before I'm wondering if this "can" has anything to do with the breaklights..
