I bought a bunch of brackets and these are some I’m not sure what they are.
1967 and back#10 is a big Mopar alternator bracket.
Thanks girlie! I knew there was a break, but I couldn't remember which was which. Moochas grassy ***.1967 and back
Actually it’s not. I have several of the BB Altenator brackets, but this one is bigger. Maybe for a motor home engine. I’ll try and get a picture of the other BB brackets I have.#10 is a big Mopar alternator bracket.
This one is larger than the one your thinking and has no attached threaded lug. I’ll get a picture of this one compared to the one your thinking. ThanksLooks like a mopar small block power steering bracket. The one that bolts to the timing cover on the driver side and makes a pivot point to adjust the belt for the steering pump
Here is a comparison picture.Actually it’s not. I have several of the BB Altenator brackets, but this one is bigger. Maybe for a motor home engine. I’ll try and get a picture of the other BB brackets I have.
Here is a comparison picture.Looks like a mopar small block power steering bracket. The one that bolts to the timing cover on the driver side and makes a pivot point to adjust the belt for the steering pump
Yeah. It is. 66 and prior.
Sho nuff, Roy!Yup and you just very well might be right. Thanks
Hey you did better than I did. I didn’t find a thing on it. ThanksI looked up this number it matches the number of the front generator non power steering bracket for GM 409 engine.
Sorry could find the others!
Looks like one I have on a 383 with AC. Thought it was P/S at first.And I'm almost 100% certain this is the lower alternator bracket that goes with your 66 and prior one.
That might worth a little bit right there!I looked up this number it matches the number of the front generator non power steering bracket for GM 409 engine.
