1965cudav8
Hey guys, I have a 65 cuda that I just did a bunch of brake work on. I replaced all the hard lines (3/16), cleaned and rebuilt the brake assemblies, and replaced the original single bowl master cylinder with a dual bowl master. I ran the primary port line down to a brass T which then diverted to the two front brakes. The rear I ran straight back to the junction on the rear axle. I bench bled the master, installed it, then started to bleed the system. After fixing two leaks, I was able to bleed the system.
HOWEVER, the problem is that the brake pedal will not return off the floor by itself. We put the car in neutral and rolled it and the brakes worked when the pedal was depressed, but would not come back off the floor. I can use my toe and pull it off, so its not stuck there. There are no leaks apparent in the system.
I am supposed to drive this car 3.5 hours on Monday to get it home, im currently working on it a few states away where I bought it so that I can drive it back.
Anybody know whats up with this? Im scratching my head.
Thanks
D
Thanks
D
