illcuda65
I am looking into buying a different motor for my 65 barracuda. All of you experienced Mopar Mechanics please give me an idea of the value of the following motor:
1971 340 Block
Ø Bored. 030 Over
Ø Keith Black-Hypereutectic Pistons
Ø Steel Crank
Ø Block Decked Appx. .015
Zero Piston Depth/Height
Ø Chromoly Rings
Ø Rotating Assembly Balanced
Ø 360 J Heads / 1.88 Intake Valves
Ø Purple Cam Shaft
.484 Lift/.284 Duration
1971 340 Block
Ø Bored. 030 Over
Ø Steel Crank
Ø Chromoly Rings
Ø Purple Cam Shaft
