HELP Turn Signals
SharpDart71
Irwin, PA
Hi all
Looking for some help tracing my turn signal wiring, if anyone has knowledge of this or can narrow down a diagram. I’m trying to use the chassis manual but it just isn’t helping. Note that my Hazards ARE working, signals aren’t. Thanks!
Each circuit has its own flasher, have you checked the one for the signals?
Do your tail and brake lights work?
If those lights are working then your wiring should be good to the lights. Did you check the relays? This is a hard thing to troubleshoot without more details, please tell us what you have done so far . From your initial post I'm assuming that you do have a factory service manual. If you don't, just Google it online there are many free downloads for this. I have had issues with the turn signal circuit and I found the problem in the steering column turn switch. You can take a look there.
