help with cam ID plz
RAMM
Ontario, Canada
Buddy at another shop is working on a 340 (372) and pulled this out. I can't seem to find any info. Any help would be great. J.Rob
That P number is a Mopar Performance number. I can't find anything on it, but all of the P434... numbers are for the 426 Hemi. Might be an older grind.
Using Google I can find references to the cam and it is a small block cam but none of the links list the specs.....
Found this link but no specs on cam
Timing issue - Mopar Forums
That appears to be a custom grind done by Racer Brown. I think Jim Dowell ended up
with all of Racer's masters etc. Years ago he was at 410-866-7660 and might have
the info you're looking for.
