Help with engine to trans bolt sizes
Emeraldart
Active Member
Just finished installing my 360 and 727 transmission in my 71 Demon.
The top two bolt sizes, left and right of centre are 3/8 coarse, the bottom 4 are 7/16 coarse...what sizes are the ones in between...the bolt hole where the transmission dipstick tube mounts and the opposite one on the other side.
I tried 3/8 they won't fit and 5/16 is too small...it has been a long day on the wrenches I know I am missing something simple..Thanks James
yes..the 4 bolts the come from the trans into the block are 3/8 ..same as the intake..
the two bolts on the bottom that go from the engine into the trans are 7/16...
run a tap to clean up the threads.
