Help with K Frame ID-Solid bottom plate....
chickendeluxe
Silver Spring, MD
Were any A Body K Frames produced without "OPEN" Holes on the underside plate?
Maybe this is an early 67 one I intend to use in my 68 B Cuda. ?????
Thanks.
you don't want a 67. the 68-72 is a better k-frame because of the way the idler arm mounts.. has a through bolt instead of just a stud. pics of what you have and are actually asking would make things easier.
Pics of post kframe
It looks like it came off one of the dukes of Hazzard jump cars
SOOOO Wrong. The Dukes of Hazzard used a B-Body!
It would have been more astute if you noticed the areas welded up for reinforcement ie....
Steering Box gussets, LCA and edges for function before form since its going ON a Dukes of Hazzard B-Cuda. :)
Thanks for everyone elses input.
