66VALIANT said:
oh by the way i like your valiant nice all original?
Thanks, for the compliment.
Look at Bigblock dart,for more better hints.
http://bigblockdart.com/
Not exactly all original, it is a factory V8 273 2bbl car;
I added {Midas installed} dual exhaust,with Dynomax Super turbo mufflers,
and 69 era Dart chrome tips;
I added electronic ignition, I rebuilt a 318,and put a cam in it,
added an old small port Edelbrock intake and Edlebrock electric choke 4bbl.
I put # 302 small block 1987 era heads on the engine,they have smaller combustion chambers, than the normal 1967-1984 ish 318's did.
I put 14 inch rims/tires/hubcaps on right after buying the car,
the stock size tires were 7.00x13, the tires on the car were much shorter,and
the speedometer was off by over 10 mph at 60 mph.
I am using 205/70/r14 tires,"noname" off brand tires. 14 x 5.5 rims,
which are a little harder to find in the small bolt pattern. The 14 x 4.5 narrow rims are easier to find,and would be ok for 195/75x14 narrower tires.
I also bought a new windshield thru Diamond/Triumph auto glass,
they installed it for less than $300.00
