hemi tone ring !!! need help
crazy 340
quebec canada
hi
I have a 2007 ram with noisy hemi
bought a 2017 junkyard engine to replace the tired one
knew I hade to replace the front covert to keep A C compressor in place
but found out the crank reluctor arent the same either
the 2007 have 32 teeths
and the 2017 have 50 plus teeths
so the pcm will never start the engine
does someone know if I can use my 2007 reluctor Wheel
on the 2017 crank or does someone have a reluctor that will
work on my 2017 engine
thanks Bob
As for fit... look on rock auto, sometimes they had dimensions of parts
but mine is 5.7 hemi
and yes it s a really good thing to know if I decide to
intall the 32 teeths crank reluctor I will have to see
if on the cam they are identical from the 2007 to the 2017
but Im sure they is a diference because the cam senser and the crank senser
should speak the same language to the pcm as I can say
maybe I will end up using the 2009 pcm I have on the shelf
and have it tune
damn I love my small block in my duster so easy to work with
