highflyer
So iv had time to get onto the wiring the last few days,,,brown wire connects at the switch connector same volt both sides..5.3..firewall connector both sides 5.3...at the ballast resistor 5.3 at the coil 5.1..blue wires at the both connectors ..11.8 resistor... 11.8 ign mod plug same...my resistor is 4 prong with the 1.4 value on the bottom and the 6.0 value at the top..the brown wire is plugged in at the bottom down stream from the blue..the schenmatic shows the brown wire p[lugged in at the top yet mine is plugged at thwe bottom...ideas and help...please.still havnt figured why it wont start whiule cranking but trys while you let go of the switch..the other thing is the blue wire has 10.3 at the alt but if you disconnect it and recheck,it has 12.3..j
