What are the approximate stall speeds on factory 360 high and low stall speed converters? I have a mild 360 that is currently running a factory high stall converter. I am getting a rebuilt L/U trans and was contemplating a re-man high stall converter for it. I see that bulkpart.com has other converters that stall 18-2200 and 22-2600rpm. Do the stock h/s verters stall around 22-2400 rpm?
My 360 has 9 1/2comp, Crane 216* .454 lift cam and has 3.23 gears.
I just wanted some opinions before buying the converter for it.
Thanks!
Thanks!
