Baxter61
I have a Holley 3310 with a Pro-Form main body. Im asking in general how to do this but also because Im working on my app specifically. Im using my LM1 to tune. When I floor it from 3k in drive its about 12.2-12.4 AFR down low and leans to about 12.8 at peak RPM. I need to play with the actual AFR at the track to get it right, but I want to lean it out at the lower RPM while not affecting high RPM reading, essentially flatten the fuel curve. How do I do this? The main body has adjustable air bleeds and the secondary has a metering block instead of plate.
