fishy68
Tyr Fryr's Inc.
Selling this nice used 600 Holley vacuum secondary manual choke list 1850
carb for a friend. Has about 4-5000 miles on a rebuild and it ran fine. My buddy upgraded to a stroker and felt this carb wasn't enough. The only issue it has is someone previous to my rebuild drilled out the base plate mounting holes to 1/2". I assume this is because they had a intake with stripped holes and instead of installing heli-coils they drilled and tapped the studs to 1/2". It's not an issue using with factory sized 3/8" studs when you use some shoulder bushings that will be included with it. I took a picture of one corner of the carb with the bushing installed for you to see. I guarantee they are drilled correctly and you won't have any trouble with it.
Asking $75 plus shipping from central IL. PM me if interested
