340Duster247
my fuel system is acting weird. I can't seem to get psi any lower (at idle) then 7.5 psi. And it cranks up to 14 if I tighten in on reg. It's a bypass system. Regulated after the carb. I've pulled apart the regulator and nothing looks wrong. Diaphragm look fine.
I pulled the pump and cleaned internals. lol good there
I run a black Holley pump. -8 all the up front to a block. -6 to fuel log/carb and -6 back to tank.
Problem 2. When I blip the gas wot for a sec when driving. Fuel pressure drops to 3 psi. Is this normal. Haven't tried a full wot pull yet.
