72Dodge
All prices are plus the ride. I'm good at packing. If you can pick up, you might get a little better deal for multiple items depending what it is.
Just PM me with any questions, if you need better/different pictures, or if you want to throw some money my way.
Check out my interior parts for sale thread also.
I'm starting to clear out some things I don't need to raise money to hopefully buy a second Mopar next year. :burnout:
(Also, I will be posting up a complete carb-to-pan (but no exhaust manifolds) '69 340 shortly too... not running, rebuildable, for pick up only)
1968 340 intake. #2531915. (Above that, 08047). This is the part # correct to finish off your '68 340 to factory. Great shape, it's been well-cleaned and painted Hemi Orange (so would need to be repainted to be correct). Doesn't come with anything else pictured, just the intake. I'll remove it from the engine when it sells. $150.
Holley 80555 2390 carb, rebuilt, real nice, 650cfm. Decided to go a different direction. $125.
Jack with hook, spring, base from a 1970 Dart. Very very nice condition, not perfect but far better than most originals I've seen. I'm stupid to sell this, but $175 will take it from me for the cause.
Fuel filler tube for 1970 Dart. The other tube is for the CA emissions stuff (I believe same as '71 otherwise?), but looks like the tubes have been broken or cut. Might be junk. But, it's free if you want it with filler tube for the extra shipping, or I can toss it. $15.
Windshield washer manual foot pump from 70 Dart. Pushes air when pumped. The tape is just there to hold the original bolts on so they don't get lost. The fluid bottle is aftermarket, but not cracked, works with this pump. $15 for both.
Thanks for looking. Thanks FABO for the ad.
