"Home-Brewed" Pinion Yoke Wrench.
"Dart67"
Jessieville, Arkansas
I need to remove the pinion yoke on "Ole Blue" to Up Grade to larger U Joints.
As you know, the pinion nut has a minimum torque of 240 ft lb. I had no way to hold and keep the pinion from turning.
So, I hit the scrap pile again.
One piece of 3/8" thick plate steel and one piece of 24" long 3/4" iron pipe. About an hour of layout, cutting and assembly.
I now have a Pinion Yoke Wrench.
That is one of the reasons I bought the HF cordless impact gun. It also makes rotating tires a real quick job with taking off lug nuts. I always dreaded all those nuts but now it's a piece of cake.
The HF earthquake cordless impact I bought is the best $220 I ever spent.
That's cool ! I've been pretty lucky the few times I had to swap a yoke or replace a seal, by tightening up the emergency brake cables and mashing the pedal thru the floorboard....lol.
View attachment 1715989713 View attachment 1715989714 View attachment 1715989715 View attachment 1715989716 View attachment 1715989717
Home made and handy.
